Epic Report - Not able to see the existing Epics
koteswararao
March 14, 2019
in epic reports i am not able to see the existing epics
Venugopala Naidu
Hi @koteswararao
I am suspecting that it is due to the fact that you have made changes on the Column Configuration, making the status of the epics a bit messed up.
Kindly try to perform reindexing and see if the problem still persist.
Moreover, the far right column is the column where issues will be closed and will not appear on the board anymore. So the Resolved issues should be in the far most right column and not on the In Progress column.
Jack Brickey
@koteswararao , you seem to be posting a lot of duplicate posts or very closely related.
koteswararao
March 14, 2019
I didn't get solution still
Nic Brough -Adaptavist-
March 15, 2019
Asking the same question over and over is not going to get you any further.
It's also very rude - some people are taking time to answer your questions, and then seeing you ask the same one again which tells them that you are ignoring their answers and dismissing them.
Please stop repeating questions, and please listen to the answers you get.  Even if an answer does not help, you explaining why it does not is polite and may help you get a better answer that does.  Starting from scratch, repeatedly, is not helpful.
Like • Jack Brickey likes this
Learn more
