I'm coming from Microsoft Azure Dev Ops Board where an Epic was attached to Features and features were attached to stories. I also understand the hierarchy of work, Epic, Feature, Story. What I am unable to understand is how to replicate this in Jira. I worked in Jira 5 years ago, but at a different level where hierarchy wasn't my concern. Now as a CSPO and CSM, it is. Please provide me with a resource in this community to read/understand or provide me with screen shots as to how to link the hierarchy of work in these stages: Epic/Story/Task
Hello @Jessica Brasington
The short answer is that you cannot exactly replicate that hierarchy in Jira with only native Jira functionality.
In Jira the issue type hierarchy for the Free and Standard versions is:
Epic (level 1)
|-- standard issues (level 0)
|-- subtask issues (level -1)
Epic is a unique issue type in Jira that has some special functionality associated to it. You cannot create additional issue types that will be function the same way in Jira.
Standard issues are the main working level of issues. This includes typically Story, Bug, and Task. You can create additional custom issue types at this level.
Subtasks are another special issue type. Subtasks cannot exist on their own. They must be connected to a Standard Issue type. By default just one subtask issue type is created, but under some circumstances you can create more.
Jira does not allow modification of this hierarchy at these levels to insert more levels.
Issue types at the Level 0 are the ones that are tracked in Burndown/up charts.
If you have a Premium or Enterprise subscription you can add levels above Epic; i.e.
Theme
|-- Initiative
|-- Epic
|-- standard issues
|-- subtasks
Jira will let you use generic issue linking to artificially create a relationship between issues at the same or different levels, but it will not treat that as a "parent/child" relationship.
So, in a Standard subscription you could use generic issue linking to link other a Task to a Story and use that to mean those are children of the Story. But Jira's native functionality would not see that as a parent/child relationship.
If it is critical to have functionality that would support a Task (level 0) being a child of a Story (also level 0) you will need to consider third party apps that would give you added functionality to establish and interpret that hierarchy.
