Error 400 while posting removeAndSwap
Gilad Waldman
Built an automation that once a version is being released, the flow that runs over all versions and identify the empty ones, and delete them.
It was working fine for a few times until stopped working, and im getting Error 400:
{"errorMessages":["No content to map to Object due to end of input"]}.
{{AllVersions}} contains a list of version ids separated by commas.
Anything wrong in my request? seems like this is a format/content issue
Marc - Devoteam
September 19, 2025
Hi @Gilad Waldman
Does the call work if you use it in an app like postman?
But I think you need a branch in your rule to branch over the list of issues in the {{AllVersions}} variable.
Gilad Waldman
That's correct. working properly with postman.
also, as you can see, im running this on a branch per every smart value
