Error after upgrade. The Jira server could not be contacted....
Ivaylo Stanev
I just upgraded all my plugins (UPM, Tempo etc) to their latest versions. After the upgrade (I assume this is due to the upgrades), when I click the Agile tab top arrow, I see the following message:
The JIRA server could not be contacted. This may be a temporary glitch or the server may be down.
I use the following downloaded versions under Linux: Jira 5.1.2, Greenhopper 6.0.1
Tested under Win as well, and the same problem appears after upgrading all plugins.
Any idea how to fix this?
3 votes
Renjith Pillai
August 27, 2012
Ivaylo Stanev
Yes, this fixed the issue. Thanks a lot!
Related links:
https://jira.atlassian.com/browse/GHS-5633
https://jira.atlassian.com/browse/JRA-29386
Ivaylo Stanev
UPM 2.7.2 and Greenhopper 6.0.3 - issue is still not fixed.
Jaejoon Jung
Solution is a above answer commented by Renjith in my case
Ivaylo Stanev
Yes, the solution is to simply restart Jira :)
Jaejoon Jung
I have same problem. I use JIRA 5.0.5 and Greenhopper 6.0.1 on Linux
Nic Brough -Adaptavist-
August 26, 2012
I'd start by reading the log file and looking for errors in there.
Register now
