When I try to connect LDAP in the Scriptrunner, the following error appears:
Failed to validate connection: nts.local:389; nested exception is javax.naming.CommunicationException: nts.local:389 [Root exception is java.net.SocketException: Connection reset]
Similar LDAP settings in the Jira User Directories and everything is fine there, there are no errors
After updating the scriptrunner to 6.13.0 LDAP was enabled
