Am writing a custom HTML form to create issues in JIRA via the REST API (rest/api/2/issue). One of the fields is a custom JIRA field with multiple options (single select), but I'm unable to create issues when I include that in the JSON. The error I'm receiving is "Could not find valid 'id' or 'value' in the Parent Option object. The JSON I'm supplying looks like:
{ "fields": { "project": { "key": "PTP" }, "customfield_10401": "my project request", "customfield_11700": "11610", "summary": "my project request", "description": "Compliance Program", "issuetype": { "name": "Epic" } } }
where "customfield_11700" is the single select custom field. (customfield_10401 is "Epic Name").
The supplied id "11610" is a valid ID (known value) for the custom field - I retrieved it from the createmeta API.
I've tried to create an issue by supplying the 'ID' and the 'value' for the customfield_11700 with no success. I now the customfield_11700 is the offender because if I remove the 11700 field from the JSON, the issue is created successfully.
Any ideas on what I should try?
Try this:
"customfield_11700": { "value": "Compliance" }
I am facing same problem in jsd server apis.
I setting custome field value using FieldID and InputFieldValue classes.
input fields working as expected but select field not working.
It shows above error.
for input field i do following things.
FieldId fID = FieldId.withId("1");
fVlaue = FieldInputValue.withValue("asd");
for select customfield field i do following things.
FieldId fID = FieldId.withId("2");
fVlaue = FieldInputValue.withValue(FieldInputValue.withValue("selectedoption");
please help where i am wrong.
try passing the value and not the id. See examples here.
Jobin, thanks for the suggestion and the link, but no luck. I tried a number of variations in the JSON, but I conclude there's something special about single select fields. Here's what I tried:
1. JSON using 'value' for customfield (FAIL):
{ "fields": { "project": { "key": "PTP" }, "customfield_11700": "Compliance", <--- using value "summary": "my project request", "description": "project description", "issuetype": { "name": "Epic" } } }
{ "fields": { "project": { "key": "PTP" }, "customfield_11700": "11610", <--- using id "summary": "my project request", "description": "project description", "issuetype": { "name": "Epic" } } }
3. JSON using sqaure brackets (as shown in the examples) (FAIL):
{ "fields": { "project": { "key": "PTP" }, "customfield_11700": ["Compliance"], <--- using value in brackets "summary": "my project request", "description": "project description", "issuetype": { "name": "Epic" } } }
But then, I tried to update a custom field of type text - and that SUCCEEDED:
{ "fields": { "project": { "key": "PTP" }, "customfield_10600": "Compliance", <--- using text field "summary": "my project request", "description": "project description", "issuetype": { "name": "Epic" } } }
SOOO, that's what gets me to the conclusion that the single/multiple selects are expecting something different.
thoughts?
-Peter
were you able to find a solution ? i am having the same problem
I have almost the same issue.
image2016-9-21 13:38:15.png
Now, when I try to create a bug using cURl, I get error message as
image2016-9-21 13:36:24.png
My jason script is
image2016-9-21 13:39:44.png
But if i do "ID" instead of value im good. its working fine. My requirement is that I should not use ID because if I use ID it will always create a bug only with that ID. So how would i be able to use value instead of ID. Please advice.
Read the story
