Error following upgrade of JIRA Agile
ScottW April 8, 2014
We recently upgraded to JIRA Agile 6.2.2 and are getting these errors when opening issues.
greenhopper-epics-issue-web-panel
Error rendering 'com.pyxis.greenhopper.jira:greenhopper-epics-issue-web-panel'. Please contact your JIRA administrators.
details-module
Error rendering 'com.atlassian.jira.jira-view-issue-plugin:details-module'. Please contact your JIRA administrators.
Our IT team has attempted a few different approaches to fix the issue including ensuring we're on the latest versions of Java, JIRA, and plug-ins. But we haven't been able to resolve.
In our logs, we're getting references to errors indexing custom field customfield_10505 which happens to be our Sprint field. Any suggestions?
Tiago Comasseto
April 11, 2014
Hi Scott, I found a similar case in our support history and in that case the problem was corrupted entry in the database.
Try to execute this query:
select * from issuelink where linktype = (select id FROM issuelinktype where linkname = 'Epic-Story Link') AND destination NOT IN (SELECT id FROM jiraissue) or destination is null OR source NOT IN (SELECT id FROM jiraissue) or source is null;
In case it return anything create a backup of your database and remove the entry.
Cheers
ScottW April 16, 2014
Thank you. We got some results. It looks like the problem is related to some sub-tasks that didn't get deleted when the parent was deleted. How do I remove the orphaned sub-tasks?
Tiago Comasseto
April 17, 2014
Hi, we have a KB article to this issue here. Basically the corrupted entries need to be removed.
Cheers
ScottW April 30, 2014
Worked like a charm. Thanks!
Kaisersberger_ Klaus
I cannot access the KB article due to insufficient permissions. Could you fix that?
Tiago Comasseto
October 12, 2014
Hi @Klaus, sorry my mistake, forgot to remove the restrictions. It's public now. Cheers
krishnan
Hi Tiago, Still unable to access the KB article due to insufficient permissions. Also I would like to know if the above query, returns empty set and still I get that error. What could be the issue? Thanks
Aleksey Omelchenko February 12, 2015
Hi Tiago! Could you please check one more time restrictions of this page? I can't also see it as well
Denis Yaparov
Hi @Tiago Comasseto @Tiago Comasseto , Please, recheck the access settings to the KB article. We are anable to delete such subtasks. Also, I'm unable to request access to KB article from info message about access permissions. Denis
Danilo Conrad
February 13, 2015
To everyone trying to access the article mentioned by Tiago, it has been moved from the GreenHopper Confluence Space to the Agile Confluence space: https://confluence.atlassian.com/display/AGILEKB/Issue+screen+displays+error+rendering+greenhopper-epics-issue-web-panel
Denis Yaparov
Hi Danilo, Thank you for reply! Actually, here are two different issues, looking similar: 1. Broken link between Epic and deleted issue (issue from KB), linktype = "Epic Story Link" 2. Orphaned sub-tasks with existing link "jira_subtask_link" and deleted parent, and field Sprint, it became crazy in this situation. (issue from this question). Deleting link using Integrity Checker tool didn't solved this issue in my case, only faking parent link did (see my answer to this question). Both cause errors on rendering issue view, but they are different issues.
Denis Yaparov
Just hit this issue with sub-task without parent and Sprint field.
Thanks to answers to this question and @Jamie Echlin [Adaptavist] 's Script Runner - I was able to resolve similar issue.
  1. I created new issue in the same project
  2. I added a link between new issue and the sub-task
  3. In DB I changed link's type, source ID and destination ID. Sub-task's ID must be in destination column
  4. Using Script Runner I cleared Jira's cached data
After these steps I was able to remove the sub-task and its new parent.
