Error in SMTP configuration
Antoine
August 17, 2016
I've this error, but i don't know how to resolve it. Anyone know ?
I'm configuring a SMTP server on my Evaluation Instance.
Comment if you need more informations.
Nic Brough -Adaptavist-
August 17, 2016
That means the SMTP server you have set up either does not accept the credentials (username/password) you've configured in JIRA, or that the account you are using is not set up to accept mail.
It also might not be running, or firewalled off, but I'd expect an "unable to connect" error in those cases.
The JIRA application log is likely to have a bit more detail.
Antoine
August 17, 2016
Ok thank you for your answer !
Register now
