Error on extracting report
Paulo.Cerqueira February 14, 2025
Hi team,
Recently, for the past 3 months or so, I am getting errors when I try to extract reports on Jira using excel button.
See images below
Thanks you all in advance.
HI Team,
Thank you all for your help. I got the answer from another question in the community. This is a problem in the Jira software.
Solved: How to resolve Import error when exporting into Ex...
Aron Gombas _Midori_
In addition to what @Vishal Biyani suggested, there are further hints here as well: https://midori-global.com/blog/2021/10/15/what-to-do-if-jira-cloud-for-excel-is-not-working
Vishal Biyani
February 14, 2025
@Paulo.Cerqueira
it is possible the authentication/authorization is not working properly.
Option 1
Can you try clearing up your browser cache and check?
Option 2
Open Excel. install JIRA plugin if not installed. Then import some data. it will validate your account and if import is successful, your error in browser should also resolve
Option 1 - I tried and didn't work
Option 2 - The company wouldn't allow me to install this plugin. Which I think don't need as I have been extracting this report every weeks for the past years and never needed such plugin.
Vishal Biyani
February 14, 2025
It is not a plugin but an Add On for Excel. If you have it, try downloading the data from your jira into excel and see if that resolves the issue
I can't install it.
Vishal Biyani
February 14, 2025
Open Excel
Home -> Add-ins
search for JIRA.
You will see Add button corresponding to JIRA Cloud for excel.
See if that works for you
HI Vishal Biyani, The picture I posted above, shows that I CANNOT add add-ins as per company policy.
I still think that should be that complicated if the button is already that and I have been user same for  along time now.
