Error using Jersey with Jira 7.1.6 and Java 1.8.0_131
John Bishop
July 19, 2017 edited
We developed an add-on in Jira 7.1.6 which makes calls to an external web service and receives back an xml response. Then we use Jersey to deserialize the response like this:
GetServiceListResponse serviceListResponse = clientResponse.getEntity(GetServiceListResponse.class);
These are Jersey dependencies we have defined in the pom.xml:
<dependency>
<groupId>com.sun.jersey</groupId>
<artifactId>jersey-client</artifactId>
<version>1.8-atlassian-11</version>
<scope>provided</scope>
</dependency>
<dependency>
<artifactId>jersey-json</artifactId>
</dependency>
<dependency>
<artifactId>jersey-core</artifactId>
</dependency>
This worked fine until the Jira environment was upgraded to use the JDK version 1.8.0_131. I've verified that the add-on works fine in all environments which have a java version older than 1.8.0_131.
Now the add-on receives the response from the web service (I've been able to output the raw text), but when we try to run the code as above serviceListResponse is always null. I've verified that Jersey is not throwing any errors or warnings in the logs.
Does anyone know a solution to get Jersey working with this version of the jdk?
I know this version of the jdk has a lot of security updates. Does anyone know if this version of Jira or the Jersey framework that's bundled in it is compatible with this version of the JDK?
John Bishop
July 20, 2017
Register Now
