Error when opening JMWE Configuration with code "heroku logs --tail"
NORBERTUS WUSANA
Hello, we are facing the issue on our JMWE configuration for workflow. The post function that already implemented times ago, now cannot opened for editing with this error
Application error
An error occurred in the application and your page could not be served. If you are the application owner, check your logs for details. You can do this from the Heroku CLI with the command
heroku logs --tail
Please help. Thank you
Teja_Appfire_ June 6, 2024
Hi @NORBERTUS WUSANA
I am Teja from Appfire.
Please accept our apologies for what you have experienced.
We identified that there was a JMWE outage that occurred on June 5, 2024, due to an issue with the JMWE API token. After our investigation with Atlassian, we have rolled the app back to its previous version to restore access. It is operational now.
If you have any questions meanwhile, please open a support ticket on our portal at https://appf.re/support
Teja
NORBERTUS WUSANA
Thank you @Teja_Appfire_ , all works now.
Trudy Claspill
I heard from a colleague that JMWE/Appfire was experiencing an outage. My colleague got that information via a support case they opened with Appfire.
You might want to also open a support case directly with Appfire about the problem.
https://marketplace.atlassian.com/apps/292/jira-misc-workflow-extensions-jmwe?hosting=cloud&tab=support
Dave Raizen
June 5, 2024
We are also experiencing this problem - it is preventing our post functions from running properly.
NORBERTUS WUSANA
Currently JMWE API down based on http://status.innovalog.com/
