Error when searching for a literal value in the fixVersion field
Andre de Castro
Hi.
 In Jira, when I run a JQL with the search examples below, I get a successful result:
fixVersion ~ “*STG*” AND statusCategory != Done
fixVersion ~ “*TRUNK*” AND statusCategory != Done
But when I do the search below:
fixVersion ~ “*PROD*” AND statusCategory != Done
an error occurs and I get the following message:
JQL error The terminal clause [*PROD*] resolves too many literals
When I accept the AI's suggestion, the error message no longer appears, but the query returns no results, even though there are records to be displayed.
 I only use native Jira.
I couldn't find a solution in my searches. Does anyone have any advice on how to solve this?
Marc - Devoteam
September 9, 2025
Hi @Andre de Castro
The error means the too many versions are found based on the fuzzy search clause.
Also see using-wildcards-in-jql-search-leads-to-errors
Adjust your search to limit the results
