Error when using Rovo Agents to Create Epic
Anonymous September 23, 2025
Message action error: [Code 400] convoai.rest.bad.request - Failed to invoke action for actionKey: jira-issue-create-bulk
As per Solved: Work Item Planner Agent - Wont create things in Ji... I created a copy of the Work Item Planner agent and gave it the necessary knowledge and permissions:
However I keep getting the same error when attempting to have it create an Epic for me:
Anja Bresemann September 24, 2025
Hi, I am getting the same error when using Rovo to open a Jira ticket. It offers to open the ticket and I click on the button after it drafts the ticket text but then the error appears: Screenshot 2025-09-24 162720.png
Anonymous September 25, 2025
That makes sense Anja! I figured I can't have been the only one but I couldn't find any online reports about this issue at all, so thought I'd raise it!
Kyle Burke
September 25, 2025
I'm getting the same error when trying to create Epics. I can create them manually but my agent fails every time.
Like Anonymous likes this
Ronald van Sleeuwen September 30, 2025
Same here, I provied all required fields to Rovo but same error keeps popping up.
Tried it with story or task, same error.  Just one simple story with like 5-10 fields.
Rovo shows the summary after providing the details and that summary looks ok.
Clicked Create story but error appears.
Can it that that Rovo is missing permissions to create story in the project? If so, where to set?
Apoorv Ketkar
October 9, 2025
Same for me. Tried to create the issue and gives me the same error
Message action error: [Code 400] convoai.rest.bad.request - Failed to invoke action. for actionKey: jira-issue-create-bulk
Rebekka Heilmann _viadee_
Hi @Anonymous and welcome to the Community,
are you trying to create multiple Epics at the same time?
I assume you clicked on "Create epic" right before that error message?
Anonymous September 24, 2025
Hello there Rebekka! Thanks for the prompt response!
I thought of adding that detail into the Q but held off because I thought it was obvious; the one time I forego adding detail haha!
Yes I did click on 'Create epic' before it processed for a minute or two before showing this error
I assume it was only trying to create the single Epic (as per preceding instructions), but how can I be sure
Sorry - it is obvious but sometimes it's the simple things ;)
I'll escalate this to the team as it looks like a technical error then, especially with @Anja Bresemann confirming.
Anonymous September 26, 2025
Thank you Rebekka. Will we hear back from you or the team on this thread?
Additionally, just curious how you go about escalating to Atlassian themselves, as I understand you don't work for them, or do you haha? I'm guessing as a Community Champion you have an escalation path?
Anonymous September 30, 2025
Hi @Rebekka Heilmann _viadee_
Do you have an ETA on when you'll hear back from the technical team?
I currently see the following, but it's been over 2 days
Hi - unfortunately not. I see the same message as you.
I'll try again via Slack.
Anonymous October 16, 2025
Hi Rebekka, any luck? What do you suggest to escalate this further, as we are paying Jira users?
@Jensen Fleming @Sherif Mansour could you look into this?
@Anonymous you could also raise a Bug with the Atlassian support under support.atlassian.com
Jensen Fleming
October 20, 2025
Hi @Rebekka Heilmann _viadee_ thank you for pinging me. I'm unable to reproduce this. Are you still seeing the error? Can you both also send me your support ticket links?
Can you also try creating a ticket without an agent, just via Rovo Chat directly?
