Sign up Log in
Error while using "Select List Conversions" behaviour of script runner
Rajat Gupta March 30, 2016
I am trying to script a drop down field  based on https://scriptrunner.adaptavist.com/latest/jira/behaviours-conversions.html#_walkthrough_pick_from_jira_issues which will load its values based on jql.
However, when I try to give the same initializing script it gives me following error message:
image2016-3-30 18:2:49.png
Can you please let me know what am I missing?
adammarkham
April 1, 2016
I assume by releases you mean versions? You would need to create your own REST endpoint for this. For an example look at: https://scriptrunner.adaptavist.com/latest/jira/behaviours-conversions.html#_create_and_test_endpoint
In that endpoint you would need to use the following code to get the version names as the "value" for a particular project:
import com.atlassian.jira.project.ProjectManager
def projectManager = ComponentAccessor.getComponent(ProjectManager)
def versionNames = projectManager.getProjectByCurrentKey("PROJ").versions*.name
Rajat Gupta March 31, 2016
Ahh.. it turns out to be environment issue. Static checker doesnot give any error  in different environment.  I am able to implement. However, is it possible to have a drop down giving "Releases" instead of "issue keys"
adammarkham
March 31, 2016
I can't reproduce it with those versions when I add it as the initialiser, the type checking is successful. Is it possible you are putting the script somewhere other than the initialiser?
You may find that the behaviour works even though the static type checker complains.
script runner version is 4.2.0.7
JIRA version is : 7.0.5
adammarkham
March 31, 2016
What version of ScriptRunner and JIRA are you using?
here is the script:
getFieldByName("Summary").convertToSingleSelect([
ajaxOptions: [
url : getBaseUrl() + "/rest/scriptrunner-jira/latest/issue/picker",
query: true, // keep going back to the sever for each keystroke
// this information is passed to the server with each keystroke
data: [
currentJql: "project = NPDAAA ORDER BY key ASC",
label : "Pick high priority issue in Support project",
// specify maximum number of issues to display, defaults to 10
// max : 5,
formatResponse: "issue"
css: "max-width: 500px; width: 500px",
Steven F Behnke
March 30, 2016
Could you post the script?
Register Now
Upcoming Jira Events
