Excel VBA returns Browser Not Supported by Jira
Joe Ketchum March 21, 2025
I'm trying to connect to my Jira project via Excel VBA.  The Authentication appears to be successful (status =200) but the response header states <Browser not supported by Jira>.  Specifying the same values in the API tool httpie.io successfully returns data.  Any obvious issues in my code below?
Sub JiraAuthentication() Const JiraBaseUrl As String = "https://REDACTED.atlassian.net/rest/api/2/" Const JiraURL = "https://REDACTED.atlassian.net/rest/api/2/search?jql=project=JOES" Const JiraUsername As String = "REDACTED@yahoo.com" Const JiraApiToken As String = "REDACTED" ' --- Construct the Authorization Header --- Dim AuthString As String Dim EncodedAuthString As String AuthString = JiraUsername & ":" & JiraApiToken EncodedAuthString = EncodeBase64(AuthString) ' --- Example API Request --- Dim Http As Object ' Set Http = CreateObject("MSXML2.XMLHTTP") Set Http = CreateObject("MSXML2.XMLHTTP.6.0") 'trying another version ' --- Prepare the Request --- With Http '.Open "GET", JiraURL, False .Open "GET", JiraBaseUrl, False .setRequestHeader "Authorization", "Basic " & EncodedAuthString .setRequestHeader "Content-Type", "application/json" ' Or as needed .Send End With ' --- Check the Response --- If Http.Status = 200 Then Debug.Print "Authentication Successful!" Debug.Print Http.responseText Else Debug.Print "Authentication Failed!" Debug.Print "Status: " & Http.Status Debug.Print "Response: " & Http.responseText End If End Sub ' --- Helper function to convert to hex --- Function ConvertToHex(ByVal objByte As Object) As String Dim i As Long Dim strHex As String Dim strTemp As String strHex = "" For i = 1 To LenB(objByte) strTemp = Right("00" & Hex(AscB(MidB(objByte, i, 1))), 2) strHex = strHex & strTemp Next i ConvertToHex = strHex End Function
6 votes
Dirk Lachowski
March 21, 2025
Joe Ketchum March 23, 2025
Thanks Dirk.  I found this article as well.  I tried but didn't have any luck with the suggested solution:
.setRequestHeader “User-Agent”, “Edg / 90.0.818.46”
I did some additional research on User-Agent settings since this solution was from Jan 2022.  In searching I discovered this site with a ton of devices and settings:  https://deviceatlas.com/blog/list-user-agent-strings-2021#desktop
But, more importantly, on this site I observed that the format did not include any spaces in the specified string.  I tried “Edg/90.0.818.46” and I'm no longer getting the error.  So thanks for sending me back down this path!
Like Dirk Lachowski likes this
Dag Atle Stenstad
Hi @Joe Ketchum ! And welcome to the Atlassian Community.
Switch to WinHttp.WinHttpRequest.5.1—it provides more control, especially for authentication and proxy handling, and often works better with external APIs.
 Set Http = CreateObject("WinHttp.WinHttpRequest.5.1")
That will resolve the error message you're getting :)
Joe Ketchum March 24, 2025
Thanks for the advice Dag!  Just ran a quick test and that connection is working as well.  Now onto the actual coding.
Like Deleted user likes this
