Execute an external Script
James D_ Moore December 11, 2019
I would like to know if there is either a marketplace application or built in functionality I could use to have approved tasks launch external applications, jobs or integration.
Image is added as attachment
Option is selected from a list
Image and Option are sent to a service or job for execution
Hernan Halabi - Elite IT Consulting Group
Hello @James D_ Moore I suggest you check the Webhooks documentation, this might help you achieve what you need. Depending on the tool you have on the other end, there might be an app on the marketplace already.
Register now
