Export Transitions Log of a Issue
Jorge de Carlos October 20, 2022 edited
Hello Folks,
I would like to export ALL Transition history of a Issue from Jira, please see the following image:
Do you know if it is possible?
Best regards,
Jorge
Yuliia_Borivets__SaaSJet_
Hi @Jorge de Carlos
Here you can find how to export issue history (including transitions) with REST API or Jira plugins:
How to export issue history from Jira?
Trudy Claspill
Hello @Jorge de Carlos
There is not a native solution in the UI for this.
You could look at using the REST API and writing your own code to extract the information.
You could also look at third party apps that help you extract issue history.
https://marketplace.atlassian.com/search?product=jira&query=issue%20history
Register now
