Is it possible to create an export of all Workflow with their statuses
Grtz. Eric Roetenberg
Hi Eric,
The short answer is no. In Jira cloud there is no functionality for export in one action all the workflows. You need to export them one by one.
There should be some apps in the Marketplace that can perform this I think.
Hi @Eric Roetenberg ,
Welcome to Community :)
Please check this document if it helps for your usecase : https://support.atlassian.com/jira-cloud-administration/docs/import-and-export-issue-workflows/
Thank You,
Prachi
