Export work log from an Issue
Darryl Fernandez
Is there anyway to export the actual logged work for an issue? I have looked around but i can't find anyway to do this. I would like to export all the hours (and description/notes) for the work logged to excel
Thanks All!
Fabio Racobaldo _Herzum_
Hello Darryl,
The best way to do that is using this plugin https://marketplace.atlassian.com/plugins/jira-timesheet-plugin
All the information are available here http://www.jiratimesheet.com/wiki/Overview.html
In particular, you can define a filter to report an issue or an issue subset, access the Time Sheet Report and extract all data within in excel.
Hope this helps,
Fabio
Darryl Fernandez
Thanks Fabio, i will look into this plugin
You're welcome Darryl
Nicolas Werle _Decadis AG_
Hey,
we released an add-on "xPort - Custom Worklog Export for JIRA" on the Atlassian Marketplace including the following functions:
  • Create individual templates using your own corporate identity with optional project information, formats and your own images
  • Export worklogs & JIRA project information instantly
  • Generate automated performance records for your employees
  • Send reports automatically via email (in predefined time frames)
Please click here for more information: https://marketplace.atlassian.com/plugins/com.decadis.jira.xport/server/overview or contact us directly via email to atlassian-marketplace(at)decadis(dot)de
With best regards
Nicolas Werle
(Decadis AG)
Register now
