I'm trying to export my Jira issues to a CSV file. There is built in functionality in Jira that allows me to export issues (Issues --> Search for Issues and then click on the Export link on the top right corner and choose the format I need.
However this only allows me to export 1,000 issues at a time. I have to use the search to filter out the issues until it is below 1,000.
I was wondering whether there's a way to export more than 1,000 issues at a time?
Jason
Hi @Jason Yeung ,
You can set these parameters through the UI, using the "Advanced Settings" in the Administration section.
thanks for the information. I see the setting and will change if needed (balancing the quantity and memory issues).
Hi @Jason Yeung
Out of the box this is not possible. You would be better off using a 3rd party plugin that does not have this restriction. There are a bunch of them in the marketplace.
Regards
Register today!Online forums and learning are now in one easy-to-use experience.
