Exporting project data without installation information etc
Balaji February 28, 2018
Is there a way to create a export/backup without installation specific info like SEN ID, installed add-on and other such info. I just want to share the whole project data  - purely technical data of a project rather than such installation specific info. When I see the zip file created by the backup feature, it contains all such info - which I may not want to share. Is there a way to do this?
Jack Brickey
@Balaji, I'm not really sure what you are going for here. If you just want to share all of the issues and associated fields you could simply export the list of issues in the project to CSV.
  1. In search for issues use JQL --> project = xxxxx
  2. Click the ellipses to export all fields to CSV
you may be looking for something more?
My intention is to share not the issues but also the other setting of Jira (workflows, status, resolution, schemas ..)
