External/portal-only customers included in search
Ali Azzam
When searching on issues and filter on users (reporter, assignee etc.) external/portal-only customers also show up on the list. This is quite annoying if you are a big company and doesn't know all the names of your colleagues. Then you can't differ between customers and colleagues.
DO anyone knows how to fix that, so we only see internal users. It's OK if I have to choose project first, before the system knows to exclude external/portal only customers from the result.
Marc - Devoteam
March 20, 2025
Hi @Ali Azzam
Portal only users or customers can exist only on JSM projects.
So to exclude this and not require this information you could exclude projects of the type JSM in your JQL.
Use this clause in your JQL: projectType != service_desk
Ali Azzam
Hi Marc,
If I go to issue navigator and only select a software project (not service management) I still see all these external users.
I need a solution where we can go to issue navigator and just select assignee, reporter or other user profile fields, without the need to go to JQL and type in something to exclude external users.
Br. Ali
Marc - Devoteam
March 25, 2025
Hi @Ali Azzam
This is not possible.
All users that have reported an issue in the system will be listed, as this sis the possible reporter of an issue.
There is no option to exclude people.
Like Ali Azzam likes this
Ali Azzam
Hi Marc,
Thanks for your help.
Br. Ali
