Facing Problem in Custom Field of jira
amit anand June 21, 2021 edited
We have upgraded jira from v8.5.3  to v8.13.7 and after upgrade i am facing problem in some of custom fields.
This is mainly into multi select field.
I can see script is not compiling and getting below error.
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script10.groovy: 1: unexpected token: < @ line 1, column 1. <script type="text/javascript"> ^ 1 error </pre>.
Below mention is code.
(function($) {
    AJS.$("#customfield_11000 option[value='-1']").remove(); //Removes the default value "None"
    function convertMulti(id){
        if (AJS.$('#'+id+"-textarea").length == 0){
            new AJS.MultiSelect({
                element: $("#"+id),
                itemAttrDisplayed: "label",
                errorMessage: AJS.params.multiselectComponentsError
    AJS.toInit(function(){
        convertMulti("customfield_11000");
    JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) {
})(AJS.$);
</script>
SERVER
VERSION
8.13.7
Register today
