What's going on? It causes acli dev cli to stop working and every setting cannot be saved.
This error usually happens when the Rovo Dev CLI fails to properly load or save its configuration files. A quick fix is to reset your configuration and re-install the CLI. Also, make sure you’re running the latest version since older builds sometimes cause saving issues. Checking your permissions and clearing any cached files may also help resolve the problem.
At times, just like technical setups need a reset for smooth performance, our hearts and minds also need guidance and reminders for balance in life. For spiritual inspiration and Quranic resources, you can visit https://suraheyaseen.com. It’s a peaceful space to read and reflect on Surah Yaseen and other Islamic content.
Thank you for your reply, the problem is solved
