Hey, I’d like to confirm whether there is a dedicated FedRAMP API version available, or if it is the same API as the standard version. If there is a separate endpoint or documentation for the FedRAMP API, could you please share the link?
Thank you for your help,
Hi, @Omri Efrat
Is FedRAMP a resource built on Jira, Confluence, or another Atlassian product?
You can check by looking at the URL:
fedramp.atlassian.net
, then it’s hosted on Atlassian’s platform.If the site is not hosted on Atlassian (e.g., it uses a custom domain or a different platform), then it’s not an Atlassian instance.
In that case, please contact FedRAMP support directly — their contact information is typically available on the website.
