Fetching of tickets more than 1000 in jira through REST API
Nikhila Pikkili June 29, 2021
Hi Team,
We are using the Tableau, in the current situation we are able to fetch projects ticket max 1000 no with the help of python scripts.
In the project we have tickets more that 1000 and want to fetch in single shot.
As JIRA rest API has max result limit of 1000 , so looking for solution by any plugin or scripts.
Thank you in advance!!
Nikhila
Yuliia Maidanova -Alpha Serve-
June 30, 2021 edited
Hi @Nikhila Pikkili
I advise you to try Tableau Connector for Jira app from Alpha Serve. It makes exporting extremely simple. It supports all fields of data, including Custom fields, History, Agile, and others,
Julia Turchenko
Marketing Manager at Alpha Serve
June 30, 2021
Hi @Yuliia Maidanova -Alpha Serve-
When recommending a marketplace vendor product, please ensure that you disclosure your affiliation to that vendor in your post wording. For more information about this, please see:
Atlassian Community online guidelines for Marketplace and Solution Partners
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Atlassian-Community-online-guidelines-for-Marketplace-and/ba-p/689723
Best regards,
Like SMS likes this
SMS
July 1, 2021
Hi Julia,
To follow up with what Bill mentioned, make sure your public name says your company affiliation too. An example would be putting your company at the end of your username, e.g., Julia Turchenko -Alpha Serve-. You can find an example on the link that Bill sent you.
Let us know if you have any trouble!
Take care,
Shannon
Hi @Shannon S @Bill Sheboy
Thank you for your help!
I updated my public name and edited the answer according to the guidelines.
Best Regards,
Julia
Like 2 people like this
SMS
July 2, 2021
Hi Julia,
Thank you for updating that so quickly. :)
Take care,
Shannon
