×Hi Team ,
I want to do some fields as mandatory in my Project A .Based on some custom field values .
Like in Project A , Custom field is "Issue Source" . I want if Issue Source is "Third party" then Custom field "Name of Third Party" is Mandatory .
If Issue Source is internal then "Name of Third party" is not mandatory.
Hi Sanjay
Thank you for your response.
I can confirm that ScriptRunner for Jira Cloud does not currently have Behaviours and this is something that we are considering at the moment as shown on the ticket In our public backlog located here.
Currently, this is in a gathering interest stage so we do not have any plans on how this will work or when this will be available that we can give you any information about.
I would advise that you add the use cases that you would like to see from this feature to this backlog ticket so that our product manager can see these and review these as he plans this feature.
Thank You.
Kind Regards
Kate
@Kate Kabir Thanks for information . Please find below use case .
I have custom Field "RCA Status " in my Project . And my requirement is this fileld should be mandatory when person mention "Type of Change" as Bug fix .
If he/she choose type of Change as Business Requirement , then Field Name "Business Approval" is mandatory .
And both having Issue Type is "Change Request"
Hope this clarify my requirement .
Hi Sanjay
The case study as you have described above requires a Behaviours feature. It is not possible to achieve this in the Cloud environment. We do not have a workaround to achieve this requirement at the moment.
You add the use cases that you would like to see from this feature to this backlog ticket so that our product manager can see these and review these as he plans this feature located here.
Apologies for the inconvenience caused.
Thank You
Kate
I Want this for DATA centre, and for which I need script in scriptrunner,
I need the Actual Start Date field to be mandatory when Functionality Field is selected as value "AWS"
I am here:
Hello @sanjay_sapra ,
May be it is possible with Script runner for Jira. seen many articles. Please check a few here.
it's from another plugin -- https://confluence.cprime.io/display/TR/Make+a+custom+field+required+based+on+another+custom+field
@KAGITHALA BABU ANVESH my requirement is for mandatory field while ticket generation . and field come with (*) sign as normal mandatory field . I think above answers shared by @john having condition for workflow transition.
Hi @sanjay_sapra ,
So you need to mandate a field while creating a ticket, like "Summary" field.
You can create a field configuration. and make the need field as "Required".
And edit field configuration scheme associated with the project.
Now associate the "Field Configuration" to issue type.
https://support.atlassian.com/jira-cloud-administration/docs/change-a-field-configuration/
Thanks.
Hi Sanjay,
You will not be able to make a field mandatory at creation time based on the value of another field in Jira Cloud. You can do that with Server version using ScriptRunner Behaviours add-on from what I understand. But it is not available in Cloud.
Either the field is required at create time (using Field Configuration as @KAGITHALA BABU ANVESH has said) or it is not.
At my previous job, our jira admin somehow managed to make fields mandatory based on values from another field. This was in jira cloud. I see this response from John Funk several times. I don't know how our admin managed to do this, but it worked. Can someone speak to alternates to what John is saying is not available in the cloud? Perhaps it was a simple automation rule?
Hi @Jeanne Schock - You can do it using Forms from within Jira Service Management. But not Jira Software Cloud without an add-on. And the only one I know that could possibly do it is the new ScriptRunner Behaviours app.
