I want to display the value of an issue field inside the issue description so that I can see the description text with a dynamic text element.
Description text:
The name "Nikhil Singh" is filled in from a custom field called Champion. An issue champion can change. And I want the issue description to reflect that changing detail without having to update it.
I don't want to refer to the issue field separately.
Thanks for some pointers for ideas or ways to making this happen.
Create the automation:
1.Trigger- field value change: Champion
2.Action: edit issue
a) Field: Description
b) value: The champion for this idea is {{issue.customfield_12345}}
Replace 12345 with your "champion" field ID. You can find custom fields ID at:
yourjirainstance .atlassian.net/rest/api/latest/field
Help us plant more trees
