Fields required validaor condition
Manvisha Kodali July 10, 2023
Hi
In the workflow, using Scriptrunner Field(s) required validator with the following condition.
cfValues['T Shirt Size']?.value != 'S' ||  cfValues['T Shirt Size']?.value != 'M'
It is mentioned about the condition that: Enter the condition for which this function will fire. Blank will evaluate to "true". But the condition is not working (ie., the issue T Shirt Size='S', but still validator fires). Can someone help to fix the condition.
Evgenii
July 10, 2023 edited
Hi, @Manvisha Kodali
You have an error with logic. Let's look at your condition
It fires True if size is not S OR size is not M.
In your example, T-Shirt = S, ok, first part of condition will fail, but other part will return True
If you want to check, that size is not S and is not M, you need to use
cfValues['T Shirt Size']?.value != 'S' && cfValues['T Shirt Size']?.value != 'M'
HI @Evgenii
Thanks for your answer.
Is that possible to display the transition screen only if T-Shirt is not S and M?
Evgenii
No, screen on transition is shown anyway.
SERVER
VERSION
9.8.1
