Fill field with an asset, based on another custom Field value
Tiziana Pisenti
For the transition from the status "Wandtafelleuchte Festgelegt" to the status "Modernisierungsvariante festgelegt" the customFieldId_10232 needs to be filled. The value I want in this field, comes from asset:
The customFieldId_10198 hast an object from Object Type "Raumnutzungsarten" and the attribute "Nutzungsart" is shown in this field. The attribute "Nutzungsarten" from the Object "Raumnutzungsarten" in the customFieldId_10198 has to be compared with the attribute "Raumnutzungsarten" from the objeckt Type "Standartbeleuchtungen"
When there is a match, the attribute "Beleuchtung" from the object Type "Standartbeleuchtungen" must be inserted into the customFieldId_10232.
How I can do that?
Mark Segall
Hi @Tiziana Pisenti
You'll want to insert something like this into your rule:
  • ACTION: Lookup Objects
    • Raumnutzungsarten = cf[10198].Nutzungsart
  • CONDITION (Smart Value)
    • {{lookupObjects.size}}
      Greater Than
      0
  • ACTION: Edit Issue (custom field 10232)
    • {{lookupObjects.Nutzungsart}}
