Filter Query for linked issue
Anil Kumar
February 13, 2019 edited
WITHOUT any additional add-on, is there any way to filter all issue has links.
Filter all issue has linked issue with "is caused by".
Grigory Salnikov
Hi @Anil Kumar!
I'm afraid there's no way to do it without marketplace apps.
Anil Kumar
ohh that's really sad, we need such basic feature like this as application component.
Difference between two custom fields (numeric or date field), this is another common used use-case, not available as application component/function.
Grigory Salnikov
February 13, 2019
Yes, basic JQL functionality has its limitations.
To calculate the difference between fields I used the following app:
Jira Misc Custom Fields
There are calculated fields there.
Anil Kumar
Thanks Grigory
Jira Misc Custom Fields not available for Cloud.
Like • Grigory Salnikov likes this
Grigory Salnikov
February 13, 2019
Oh, I see, my bad.
There's a way to implement calculated fields on Cloud:
Is there any way to create calculated fields in JIRA Cloud?
See the answer by @Jon Bevan [Adaptavist]
Anil Kumar
Thanks agian @Grigory Salnikov  - my wish here was for solution WITHOUT any additional add-on.
Grigory Salnikov
February 17, 2019
Yes, I see.
Nevertheless, you're welcome!
Register today
