When I create a quick filter where I exclude for instance two story parents, the filter also excludes the EMPTY parent. And I want to see the EMPTY parent stories using this filter. How to gfix this?
Hi Nikola,
Thanks for your fast answer. This is an example of the filter that I'm referring to (and excludes empty ones as well)
Parent != SCRM-1625 AND parent != SCRM-1679
I included
OR parent IS EMPTY
at the end of the query, and the filter works good now.
Thanks a lot!
I included IS EMPTY at the end of the query. Works now!
Thanks for your suggestion :-)
