Filter for stories in Epic #
Nadia Leclercq September 2, 2019
Hi there,
I cannot remember the syntax to search for stories in a given Epic. Could someone help?
Nadia
Thank you! That is the one!
Muhammad Ramzan_Atlassian Certified Master_
September 2, 2019
 you can use  JQL Search Extensions for Jira & reports, it have amazing built in queries
For your case you can use the following query
issue in allIssuesInEpic(EPIC ID)
It will get all issues belongs to the epic you provided along with any sub tasks.
Iago Docando
September 2, 2019
Also, you could configure a quick filter for "issuetype = Story" in http://YOUR_JIRA/secure/RapidView.jspa?rapidView=33&tab=quickFilters
And use that filter in http://YOUR_JIRA/secure/RapidBoard.jspa?rapidView=33&projectKey=PROJECT_KEY&view=planning.nodetail&epics=visible
By clicking in the epic you want you'll restrict the results to only the issues belongin to that epic and with the quick filter you'll get only the stories.
Hope it helps
DPKJ
"Epic Link" = <EPIC_ISSUE_KEY> AND issuetype = Story
This will list all stories in an epic. If you want to see more than story remove `issuetype` filter.
