Filter not showing subtask - due date on story level
Norbert May 6, 2022
Hi
I have a filter that should simply give me only the stories without due date.
project = "xyz" AND type in (Story) and duedate is EMPTY
The result is correct but sub-tasks are not shown on the list.
When I change the to
project = "xyz" AND type in (Story, sub-task) and duedate is EMPTY
The filter is not working at all, even if I have no due date in neither story or sub-tasks.
How can I filter just on the story level? Means show me stories with no due date but ignore sub-tasks.
Thanks a lot
Nic Brough -Adaptavist-
May 6, 2022
Your first query makes sense, you're asking to see all the stories in the project with no due-date.  It's not going to show you any sub-tasks because sub-tasks are not stories.
Can you explain "does not work" for the second query?  I would expect that to return all stories and sub-tasks that do not have a due-date set.  Is it not doing that?
Norbert May 6, 2022
Hi
Thank you for answering.
The desired outcome of the query:
Show all the stories without due date but at the same time show their sub-tasks (now I have subtask "0" which is not true, these stories have sub-tasks in many different statuses).
And show it regardless if any sub-task itself has any due date assigned or not.
Hope this described the issue better.
Regards
Marco Brundel
May 6, 2022
Hi @Norbert ,
I've you have the app scriptrunner in use you can try the following JQL:
type in (Story) and duedate is EMPTY OR issueFunction in subtasksOf("type in (Story) and duedate is EMPTY")
Regards, Marco
Like • 2 people like this
May 6, 2022
Yep, you'll need Scriptrunner (or one of the other apps that can effectively nest searches) to do this.  Thanks @Marco Brundel !
Norbert May 9, 2022 edited
Thanks guys for answer, not sure if we use scriptrunner but will check it and test it.
EDIT: it worked perfectly, thanks!
Cheers
