  • Community
  • Q&A
  • Jira
  • Questions
  • Filter subscriptions, push emails to project team members at a fixed time, but each member receives
xixi li October 19, 2022
I don't know why this is the case, but also in terms of project team members subscribing, shouldn't everyone receive the same field presentation information? Is there a permission limit here?
Andy Heinzer
October 19, 2022
For a filter subscription, each user can define their own default columns in the issue navigator. As such, for each user that does that, Jira returns those columns.  However if the user has not defined their own defaults, then the system values get used instead.  There is a feature request to improve this behavior over in JRACLOUD-60154.
I hope this helps to explain the behavior here.
Andy
John Funk
Thanks, Andy!
Boris Berenberg - Modus Create
October 19, 2022
If you want more control over the format and contents of what is being pushed to users, you can check out our app, Notification Assistant for Jira
Like xixi li likes this
@Boris Berenberg - Modus Create
Just checked the app and wanted to know how to configure the default time zone and email account information, I saw that the default for email is jira@nafjc.com.
@Boris Berenberg - Modus Create   I know that there is a limit on the number of issues in the body of the email, which is 50. In the actual scenario, there will be more than 50. Do you support the management of the next page?
That means a lot to me. Thank you.
October 20, 2022
Hi @xixi li
  • We're currently working on allowing customers to configure the outbound email and hope to have this out in the next few months.
  • The timzeone is currently shown based on what the Jira system is configured to. We have a backlog item for allowing this to be configured when setting up a notification, but this hasn't been prioritized.
  • Re: number of issues you need in an email. Do you have an estimate for the maximum number of email you need to support?
xixi li October 23, 2022
Well, thanks, but regarding the maximum amount of transactions within the email, I understand that it can be controlled to 100, after all, there will be scenarios of multiple project management.
October 24, 2022
Sorry not sure I understand. Are you saying 100 would be enough?
John Funk
Hi @xixi li
Yes, there is a limit of 1,000 issues that can be seen at one time. But I don't see a Subscription here either - this is just a filter.
Sorry, maybe I misrepresented it.
I was referring to the fact that emails regularly push the content of this filter to my inbox, and that the content fields received within the project team members' inboxes are not the same.
I would like to keep the same field content presentation.
John Funk
Everyone should see he same columns in the filter produced by the subscription. Are you saying that is not happening?
Yes, the feedback I've gotten so far is that everyone doesn't see the column fields the same.
John Funk
Let me see if I can get someone from Atlassian to take a look since you have a free account.
FREE
