Filtering on Scheduled Automation JQL Results
Tom Scoggin
June 23, 2023
I have a scheduled automation that returns the correct list of items. Is there a way now to filter that result for use in an email? Every time I try to do this I get the full list returned and not a filtered list. I'm trying to filter on the Labels field.
Code is below.
{{#issues}}
{{if (equals(issue.labels, "STAGING-APPROVAL"))}}
<ul style="background-color:AntiqueWhite;font-size:18px;">
    <li><strong><a href="{{url}}">{{key}} - {{summary}}</a></strong>
        <strong><li>Description:</strong> {{description}}</li>
        </ul>
    </li>
</ul>
Darryl Lee
Ohey @Tom Scoggin - similar to this answer the problem is that when filtering lists (or Atlassian calls it, conditional logic), smart values within the filters are always relative to the list. So this should work:
{{#issues}}
{{#if (equals(labels, "STAGING-APPROVAL"))}}
        </ul>
    </li>
</ul>
(Also, you needed a # before the if, and another closing {{/}})
ALTHOUGH now that I think about it, labels is probably a list, so I'm a little concerned if there's more than one label on an issue. Let me go test...
Tom Scoggin
June 23, 2023 edited
@Darryl Lee
This returned 0 results out of the 17. It should have returned 2. I agree it may be tricky because Labels is a list. Not sure how to maybe do a "Like" for this.
Like • Darryl Lee likes this
Mark Segall
Further to the answer from @Darryl Lee
I haven't tried myself, but you may be able to do something like this:
{{#issues}}
{{#if (exists(labels.match("(STAGING-APPROVAL)"))}}
        </ul>
    </li>
</ul>
Darryl Lee
Ah, thanks @Mark Segall - that's not quite right but it got me on the correct path. this works:
{{#issues}}
{{#if (labels.match("(STAGING-APPROVAL)").size.gt(0))}}
</ul>
</li>
</ul>
One minor note: My JQL didn't initial include ORDER by key ASC so the issues were just in random order. Adding the ORDER bit cleaned things up.
Have fun!
Like • Mark Segall likes this
Tom Scoggin
June 26, 2023
@Darryl Lee @Mark Segall Thank you for the help. This worked.
Is there a way to run through the issues twice? I need to loop through for all the Staging Approvals and then again for all Production Approvals but I can't get the second loop to run.
<p style="background-color:powderblue;font-size:30px;"><strong>CRs Needing Staging Approval</strong> </p>
{{#issues}}
</ul>
</li>
</ul>
<p style="background-color:powderblue;font-size:30px;"><strong>CRs Needing Production Approval</strong> </p>
{{#issues}}
{{#if (labels.match("(PRODUCTION-APPROVAL)").size.gt(0))}}
</ul>
</li>
</ul>
{{/}}Capture.PNG
Tom Scoggin
June 26, 2023
This worked as a loop on the {{#issues}}
<p style="color:white;background-color:orange;font-size:30px;">&nbsp;Needs Staging Approval </p>
{{#issues}}
</ul>
</li>
</ul>
<p style="color:white;background-color:Blue;font-size:30px;">&nbsp;Needs Production Approval </p>
{{#issues}}
</ul>
</li>
</ul>
<p style="color:white;background-color:Green;font-size:30px;">&nbsp;Needs REVIEW-For-CLOSURE </p>
{{#issues}}
{{#if (labels.match("(REVIEW-For-CLOSURE)").size.gt(0))}}
</ul>
</li>
</ul>
Darryl Lee
Nice!
OH! You just solved a problem I was trying to figure out a few weeks ago:
Actually, now that I read @Bill Sheboy's response more closely, that's exactly what he was suggesting (DOH).
And yeah, I was trying to avoid having to replicate the block for EVERY component. But maybe I'll just bite the bullet and do it...
