Find out who and when a field has been created
Daniel Rieder adesso February 22, 2022
Hi
How can i find out who has created a new field and when it has been created ?
Somebody has created anew field which is, in my opinion, wrong (because there is allready a requesttype which has to be used).
Pavel Junek
Hi Daniel,
With the Audit log you can find who created the new Custom Field and when. According to the set Custom Field Context, you can determine for which project it is used.
Pavel
Joe Pitt
 I STRONGLY suggest you treat JIRA like a production system, put it under change control (CR), and track all requests for any updates, especially new projects, new custom fields, changes in any of the schemes, etc. That way at least the reporter will know when the actions happen and you'll have a audit trail. I've worked many similar tools to JIRA and too many times no one knows anything about why they are configured why they are because there is no requirements or CR. Things are just done based on emails that have disappeared and hallway or lunch conversations.
 If you don't already have a separate change control tool create a JIRA project. I use a basic workflow with a few custom issue types:
 Custom field: with a select list of create, update. The description would be to create a new field or modify a current select list, buttons, etc. of a current one
 Create Project: I would have text fields for issue types, custom fields, select list/values, per issue types
 New Issue Type: description would include all fields and workflow desired.
Workflow: Select list of Create, update, delete. Description of what needed.
Other: Select list of Notification Scheme, permission scheme, field configuration, other
 This should get you started. If you aren't familiar with your CR process there should be a configuration management person to talk to.
 The goal is to manage what you do and be able to track who asked for what. For instance, if someone wants a new custom field you want to check to see if there already is one you can use that they don't know about. JIRA will let you have multiple custom fields with the same name, which will just confuse you.
Vamsi Kandala
Per my understanding, the audit logs get updated whenever Jira was upgraded to the newer version and we cannot search for the events prior to the upgrade.
Is there a way to check in the database and find out who and when the custom field was added to a particular screen?
Vamsi
