First contact resolution (FCR)
Sampath
Team
any advise here how to measures this via filter or any gadgets
if an agent is able to resolve the ticket themselves or move to another person
Aron Gombas _Midori_
@Sampath JQL has an operator, intuitively named, called CHANGED. It supports the Assignee field.
So you can craft a JQL like this, for example:
status = "Done" and assignee CHANGED after "-31d"
 If you can collect the "FCR" tickets and use another JQL query to collect the "non-FCR" ones, then you can these queries with various gadgets that can display the issue count, display 2D reports, etc.
Sampath
Hi @Aron Gombas _Midori_
Sorry for delay in respose . Thanks for your support
I try project = XXX AND  Support Level = "Level 1" AND status = Done AND assignee changed AFTER "31d"
but no display results
pls advise thanks
"31d" should be "-31d". (We are searching in the past, not in the future!)
Sampath
July 26, 2024 edited
Thanks for your always quick response
I try it but no result shows
project = XX AND "Support Level" = "Level 1" AND status = Done AND assignee changed AFTER "-31d"
Do you have any FCR dasboard how to measure it not sure on this
Expectation like this Pls suggets First Contact Resolution (FCR):
The percentage of tickets resolved during the initial interaction.
Display: Bar chart comparing FCR rates across team members or time periods.         Motivation: Highlights efficiency and reduces customer frustration.
Harold Prestage
@Sampath any success with this?
