We have the FishEye plugin installed in our JIRA instance (server). But FishEye is also set up as an application link. We are about to upgrade to JIRA 7 and I'm showing that the FishEye Plugin (supported by Atlassian, no less) is not compatible?
Our developers like to see the Commit information in the right margin. Is that from the plugin or the app link?
Fisheye plugin is a bundled plugin. It is part of JIRA 7 too. You can ignore the message.
Oh.... we are on Fisheye 3.10. We want to upgrade JIRA to 7.2.3 and Confluence to 6.x this month, then do Fisheye to 4.2.3 next month.
Will Fisheye 3.10 work with Application Links to JIRA 7.2.3? I looked at the AppLinks matrix but it was confusing to me!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
