Hi, I have a problem:
I have a project that "lose" the sequence of issues after a csv importation.
Is there any way to fix this?
My issues "jump" from the XXX-6075 to XXX-520222070
Hi @Edimara
Just to clarify, the numeric value "jumps" from...
So there's >50mil issues been created via CSV?
Are you sure those aren't two separate Project Keys? (eg. ABC-6075, and DEF-52022070)
If not, what's the search (JQL) parameters you used to get this list? Is ORDER BY in key order? Or created date order? It could be sorted another way?
Ste
Hi Stephen
I believe that when we were updated issues through CSV, at any moment we we concatenate an issue key and because of this, we created issues starts with "52022...."
I am sure that is the same project. Look at the print without censorship
Hi @Edimara
If you haven't uploaded 50mil issues, then I'd contact Atlassian - this is not normal behaviour, and you can't usually skip numbers or merge them like that.
Contact them here: https://support.atlassian.com/contact/#/
Ste
Hello @Edimara
It is possible to force the next sequence number to be used to be reset by creating a new issue through the CSV import while assigning the issue a specific issue key (i.e. XXX-5202070) and mapping that import field to Issue Key. Refer to this article:
It is possible that is what occurred with a recent import to the target project.
As per the above article it is not advisable to use the same trick to reset the issue key sequence number to a number less than the largest sequence number currently in use.
Hello @Edimara
Can you explain that more? Did you build up a value by concatenating text and then insert that value into a column in your CSV that you mapped to the Issue Key field during the import?
