Issues that are flagged should display on my Kanban board but this is not the case.
Attached are two screenshots for Issue RT-423:
1. In the modal view, you can see the issue is flagged
2. When the modal is closed, the issue is not displayed as being flagged
Am I correct in assuming flagged issues should display as yellow in the Kanban board?
Has anyone encountered this before?
Could You Please Refer This Link
https://confluence.atlassian.com/jirasoftwareserver073/flagging-an-issue-861254740.html
Hi @PVS - thanks for sending the link through. I'm actually using Jira cloud and in that description it says "The card of a flagged issue is displayed in yellow in the Scrum backlog, Active sprints of a Scrum board, Kanban backlog and Kanban board'
https://confluence.atlassian.com/jirasoftwarecloud/flagging-an-issue-777002748.html
If this is the case, shouldn't it be displayed in yellow on my Kanban board?
+1 I'm having the same issue.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
