×Is there a way to differentiate issues created via Form and issues created manually?
Hi @Mahima Srivastav , if you're talking about the Jira Work Management forms we append a Label called "business-form" to every issue created through the form. Cheers!
This doesn't work!!
Once you removed the field 'labels' you can't get this automatic labeling back. I accidently removed the field, created a form, got the field back, but now it's not generating the label "business-form"
Hi Mahima,
Try searching on the field "customer request type". If this field is not empty it means that the issue was created through the portal
"Customer Request Type" is not EMPTY
I hope that helps!
Josephine
Hi, this didn't work for me. Maybe because I am working on JIRA Work Management and not Service Management
