Form validation
kA
Hi guyz,
Please help me,
If there is any possibility to perform the form validation in JIRA OnDemand?
Thanks in advance,
Karthik A.
RambanamP
October 6, 2013
then you have to create your own validator using atlassian Connect for ondemand jira
check this
https://developer.atlassian.com/display/AC/Atlassian+Connect
kA
RambanamP
October 6, 2013
you can configure field required validator from JSU Plugin which is preinstalled on ondemand jira
check abt validator
https://jsutil.atlassian.net/wiki/display/JSUTIL/JIRA+Suite+Utilities+Workflow+Validators#JIRASuiteUtilitiesWorkflowValidators-FieldsRequiredValidator
check this doc for more information on configuration of validator
https://confluence.atlassian.com/display/JIRA/Advanced+workflow+configuration#Advancedworkflowconfiguration-validatorAddingavalidator
if you want field required on create screen then you can make it required in the field configuration for the issue type/project
check this
https://confluence.atlassian.com/display/JIRA051/Specifying+Field+Behaviour#SpecifyingFieldBehaviour-Makingafieldrequiredoroptional
kA
Hi prasad,
How to configure these one into ondemand JIRA?
RambanamP
October 6, 2013
got to administartion page
select Issues ---->workflows
select the workflow on which you want to do validation
click on edit option on right side of the workflow(it will create draft workflow)
click on new/open step name
click on create step
then click on validators tab
click on add link which is under validator tab
select the field required validator radio button then it will display the window and you need to choose the field which you need to validate
once it is completed then publish draft
Note:all the above steps are valid if you oopen workflow as in text mode
kA
Hi Prasad,
I need to validate the text in the text box field using regex.for eg the mobile number field must be contains only the 10 digit. if we are giving less than 10 digit, it will show the message like "Reqiuired 10 digit". Any thing possible like that in onDemand JIRA.
Bharadwaj Jannu
October 6, 2013
which form?
Is it workflow transition form, editing issue form, or any other form?
kA
In create issue form, i want to add the form validation in Ondemand JIRA?
Bharadwaj Jannu
October 6, 2013
Bharadwaj Jannu
October 6, 2013
import java.util.regex.Pattern;
import com.opensymphony.workflow.InvalidInputException;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
InvalidInputException e=new InvalidInputException();
ComponentAccessor comAcc =new ComponentAccessor();
CustomFieldManager cfm =  comAcc.getCustomFieldManager();
Object PhoneNumber = issue.getCustomFieldValue(cfm.getCustomFieldObjectByName("Phone Number"));
Pattern.matches("{your phone number regular expression}",PhoneNumber.toString()) == false)
e.addError(cfm.getCustomFieldObjectByName("Phone Number").getId(),"Phone number should be 10 digits"
The below link show how to add regular expression for 10 digit phone number
http://www.w3resource.com/javascript/form/phone-no-validation.php
