Format Field text on View Screen
aditya verma February 29, 2016
I am capturing a Checkbox field on my create screen. What I want is when multiple text boxes are selected on Create screen and the issue gets created, then on view screen text of all those selected checkboxes should appear on different line.
Currently it appears on the same line, separated by commas.
Could anyone please help me on this.
Nic Brough -Adaptavist-
February 29, 2016
That layout is determined by the "view template" for the field.  In order to change it, you'll either need to
  1. inject some javascript to reformat it  javascript (which is likely to be quite hard to make work reliably everywhere, and a nightmare to maintain), or
  2. hack that view template in the core code.
aditya verma March 1, 2016
Thanks @Nic Brough [Adaptavist] for your comments.
