Format JSON data from custom REST Endpoint
February 15, 2021 edited
Hi all,
I'm tasked with formatting the returned JSON Data that's returned from this custom REST Endpoint code that we're working with:
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import groovyx.net.http.ContentType
import groovyx.net.http.HTTPBuilder
import groovyx.net.http.Method
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
import groovy.xml.MarkupBuilder
@BaseScript CustomEndpointDelegate delegate2
CMRDisplay(httpMethod: "GET") { MultivaluedMap queryParams ->
def query = queryParams.getFirst("query") as String
def rt = [:]
if (query) {
String url = "https://test.service-now.com"
String uriPath = "/api/now/table/u_jira_change_data"
HTTPBuilder http = new HTTPBuilder(url)
def output = http.request(Method.GET, ContentType.JSON) {
uri.path = uriPath
uri.query = [sysparm_query:"u_jira_ticket_number=$query", sysparm_fields:"u_change_record.number,u_change_record.short_description,u_change_record.state", sysparm_display_value: "true"]
headers.'Authorization' = "Basic ${"svc-jira:buO\$qguQUgat5lNVF7GH\$3VMtjaR1o".bytes.encodeBase64().toString()}"
response.failure = { resp, reader ->
log.warn("Failed to query SNow API: " + reader.text)
def cmrState = output["result"]*."u_change_record.state"
def cmrNumber = output["result"]*."u_change_record.number"
def cmrDesc = output["result"]*."u_change_record.short_description"
rt = output
return Response.ok( new JsonBuilder(rt).toString()).build();
For a certain issue in our instance, the output is converted to string and parsed to a multi-text field like so:
{"result":[{"u_change_record.number":"CHG0010042","u_change_record.state":"Draft","u_change_record.short_description":"test app req 5"},
{"u_change_record.number":"CHG0010061","u_change_record.state":"Draft","u_change_record.short_description":"test"},
{"u_change_record.number":"CHG0016010","u_change_record.state":"Draft","u_change_record.short_description":"Test Jira"},
{"u_change_record.number":"CHG0010057","u_change_record.state":"Draft","u_change_record.short_description":"tesst"}]}
Is there any way that I can format this output to resemble proper JSON structure?
Like below:
"result": [
PD Sheehan
February 18, 2021
The first JSON output is perfectly valid for machine parsing
But if you want a pretty layout, you can output toPrettyString()
return Response.ok( new JsonBuilder(rt).toPrettyString()).build();
Ah, that was simple enough.
