Formatting a message custom field in bold and red
mel vega
I'm using Toolkit plugin and I created a Message custom field (for edit). I would need that the message displays in red and bold to make it more visible but I did not find the right code. I tried this one but it did not work:
{panel} (i){color:red} My message{color} {panel}
any ideas please ?
thanks in advance
Melissa
3 votes
Deleted user January 29, 2016
Try using html tags smile
<b><font color="red">My message</b></font>
mel vega
Many thanks for your help Gabrielle, it perfectly works now!
Deleted user February 5, 2016
Glad to help!
Brian Bachman May 4, 2016
Hi @Gabrielle Bautista [ACP-JA] - Do you have any idea what the syntax would be to include a hyperlink?
Deleted user May 4, 2016
html hyperlinks would be <a href=""></a>.
Awesome ..  Thank you!  I did search html tags in parallel and found this too.
Appreciate your help!
Cheers
Deleted user May 6, 2016
smile
Lillian Shibata-Salley
Hi - I'm trying to also do a custom field but it's not taking the html. I put in: <p><b><i>Please Test</p></b></i> and the results show the tags. When I go back to edit, it changes to: <p>&lt;p&gt;&lt;b&gt;&lt;i&gt;Please Test&lt;/p&gt;&lt;/b&gt;&lt;/i&gt;</p> and renders with tags...
Dimitris Damaskos
For me panels worked best and it looks better.
{panel:bgColor=#EAECFF}
Please Test
{panel}
But it is a matter of preference.
Like • Omar Hutchens likes this
Thanks, can't remember what I was doing back then lol but just tried it and not exactly what I was looking for... More of being able to select certain words within a paragraph (I think that's what I was doing) and highlighting certain words, phrases, having more control of the formatting.
Thanks for the option, however.
Richard White
December 6, 2018
For some reason, when I put the {panel} ..text ... {panel} code in the Default Value, it just prints it out verbatum instead of putting the text in a panel. Is there a flag somewhere to ensure wiki code will work? html tags are working, but I would prefer wiki code.
Dimitris Damaskos
December 6, 2018 edited
Hello Richard,
I checked again the code I posted in May and it looks like this:
Screen Shot 2018-12-06 at 17.12.57.png It is not exactly what was asked initially but I wanted to give another alternative.
