This question is in reference to Atlassian Documentation: Automating JIRA application backups
I want to be sure that the daily backups are stored onto a separate drive. To do this, I have created an NFS mount point (/opt/jira-backups) so that the saved backup files will be physically saved to my backup NAS drive.
This used to be a very simply thing to change. Am I reading your documentation correctly that you have taken away this configuration option?
https://confluence.atlassian.com/jira/automating-jira-backups-185729637.html
Follow this document
Uncheck that User Default directory
and put your location path
@Prashant Mali I think this holds good only for old versions of JIRA.
Register now
