Full transition name is not visible
Srilatha Pokala
Some of the Transition names we use in JIRA are longer than 10 chars. In some instances, Full transition name is NOT visible when we hover over the button. This issue happening in IE, Firefox and Chrome.
Any idea on how can we enable this functionality always.
AhmadDanial
November 27, 2018
Hello, Srilatha.
I would like to confirm if you are potentially running on an affected version that is listed in the following bug report:
Else, please confirm on the version of JIRA that you are running so we can update the Affects Version/s field accordingly once it is tested on my end. Thank you.
Srilatha Pokala
We are running on JIRA 7.11.2
AhmadDanial
November 29, 2018
Hello, Srilatha.
I reproduced in JIRA 7.12.1 and verified that I am seeing similar behavior as the bug report.
However, I would like to take a step back to understand your statement here:
What I understand here is that despite the fact that you hovered over the button, you are unable to see the complete transition name, unlike what I am seeing on my end. May I know if it is possible for you to provide me with the screen shot(s) from your side to ensure that I am able to reproduce properly together with the transition name as well?
SAPPIKATLA86 December 6, 2018
Hi , Srilatha & I are working with the jira version of 7.11.2
The transitiion name is available on hoover when user is assigned the ticket the first time(through transition post function). When user is refreshing the page or logs in freshly after a first view the tooltip is not visible on hover.
AhmadDanial
December 6, 2018
Hi there, Sahith.
I was able to reproduce the issue on JIRA 7.11.2 & JIRA 7.12.1 where the tooltip is not visible when mouse is hovered on it as you mentioned after the refresh:
I went ahead and created a bug to report this issue to the dev team below:
Feel free to add yourself as a watcher to the bug report and share additional thoughts on it if you have any. Thanks.
Like • Srilatha Pokala likes this
Srilatha Pokala
Ahmad,
Thank you for creating Bug ticket with Atlassian.
AhmadDanial
December 6, 2018
Hello, Srilatha.
You are most welcome. Any time!
SAPPIKATLA86 December 19, 2018
@AhmadDanial How does ticket resolution work? Will it be fixed in the same version 7.11.2 or come back as fix in later versions? Our users rely on the tooltip for action names that are longer than 20 chars.
