I guess the announcement is a little misleading and frightening when it says "As a result, the functionality of the Jira Road Map, Bubble Chart, Heat Map, Projects, and Labels gadgets will be removed starting in May 2025".
It is worded as thou Projects would be removed, that is the projects that group issues and form a hierarchy among issues. For those of us that do not use dashboards, it is easy to miss the fact that the gadget that lists projects would be removed.
Welcome @WebSpeed Adiministration
Well yes and no. When you select the Projects gadget there is a warning that the gadget will soon be deprecated and no longer users will be able to use it. Plus there is an announcement about this gadget.
