GDPR settings
wade furney
April 28, 2022
Can I disable strict GDPR settings?
Dave Macolino
Two examples of changes with JIRA's GDPR implementation:
1. User IDs are now represented as their alphanumeric ID vs. their email address or ID. I have many filters where I have "assignee in (user,user,user)" and it converts the username to their ID. If you want to see what users are in that filter later on, good luck - it's better to delete them all and readd them. Painful.
2. If you try to use the rest API to search on username like https://<jirainstance>/rest/api/latest/user/search?username=dale", it gives the error "The query parameter 'username' is not supported in GDPR strict mode."
I do not have any users that are within the net of GDPR and should be able to disable it on my instance if I so choose to. Is there a way?
Dave Macolino
@wade furney  - apologies - that was supposed to be a reply to @Andrei Pisklenov _Actonic_  it won't let me delete it.
Hi @wade furney ,
What do you mean by "strict GDPR settings"? Could you please share more details?
